Will a 1992 3.0 mtx intake work on a 94?
St Louis SHO
Rollin' coal
0 .· ` ' / ·. 150
No. 3.2l has EGR Everything else but the intake will work. (It will all work, but the EGR will not function and the check engine light will be on.)
JustinSane
SHO OFF
PA SHO Shop
I was wondering if the valve covers,mass air flow sensor, and throttle body off a 92 Mtx 3.0 will work on 94 atx 3.2
the things you listed will work, infact even the runners would work what wont work is the rear tank as it has no provision for the EGR. every thing else about the intake will work. the cross over tube on a ATX has larger wholes in the ends as well and some say this is better to use then the MTX with little finger size holes.
Power Surge
Palm Coast, FL
You can use the MTX intake, the casting is there for the EGR, you just need to drill and tap it and you can bolt yours on.
