SHOOFF13
SHOOFF
I have a 1995 atx and the car was running perfectly fine until we got some snow. The car was driven in the snow then parked. Didn't hit anything at all or damage anything. I started the car the next day and the car started to idle very funny. The rpm's would be at 1k then drop to 800 and keep going up and down continuously causing the car to shake rough. I figured I had got some snow into my exhaust or something so I gave it some gas to clear them out and the cars secondaries won't seem to open up and the car has barely any power. The cars right exhaust tip is making a funny chugging noise. It makes the noise at idle but makes it even worse when applying gas. Any idea on what this could possibly be? The car went for an oil change a couple of days ago and the mechanic said my k&n air filter was clogged so I figured the problems were coming from the filter being clogged so I replaced it and still the same problem is occuring but the idle only drops a very little now. I still have that chugging sound coming from the exhaust, too. There is also a bit of hesitation from when I step on the gas the car doesn't respond right away. Any help would be highly appreciated, I need to get this problem fixed asap considering I drive it daily.
