Why don't my fogs work?
goSHOgo
Akron, Ohio, USA
My fogs haven't worked since I bought the car. I put new bulbs in, so it isn't that. The fog lamp switch itself feels a little weird so maybe it's that, but I don't know. Anybody have any ideas? Oh, I tried to take the dash out to get to the switch and I couldn't even get it out. So if anyone can explain how to get the dash out, that would be appreciated too. Thanks a bunch folks.
SHONUT91
Cameron,Mo.
Check your fog light fuse.It is located to the left of the steering column and can be accessed by removing the bottom cover under the steering column.You will also need this panel off to remove the dash panel to access the switches.If you want to just check the fuse you can gain access to it by removing your auto-lamp assembly.Just look in the hole and it is right there attached to the dash support all by itself.Just look for the blue 15amp fuse.
<small>[ June 08, 2002, 07:17 AM: Message edited by: SHONUT91 ]</small>
