Agreed and I am doing the same thing.
I will be switching to full synthetic at 10,000 on my 2011 as the manual say's ok to do.
I wonder if it has to do with the "new" 10,000 mile oil change intervals? It seems like all Ford's new Ecoboost motors, both the 4 and 6's are spec'ing 10w30....
You mean 5w30 correct?
Any 2010 EcoBoost owners switching to 5W30?
Probably heat protection with the turbos.
What Ron said heaver oil for the turbos on cool down most turbo cars run 5W-30 for that fact 5W-20 isn’t thick enough for cars in colder temps or turbos.
It has to do with fluid dynamics and heat transfer. Faster is not always better, the less the number the less time the oil has to absorb and dissipate heat. So 5W-20 is higher flowing oil good for non turbo cars, but it doesn’t collect enough heat or "stay long enough" to liberate the turbo. Keep in mind the turbo is being spin at extremely high speeds. The compressor gets extremely hot and the exhaust gasses in the turbine don’t help either. The heat buildup has to be collected by the oil and some sort of intercooler air to air or liquid to air. But back to the main issue if the bearings don’t get lubricated and if not properly cooled they start to deteriorate. This is where you start developing shaft play. I take it some of the testing from ford realized the small turbos didn’t get enough/not cooled enough oil. There are 2 ways to change this oil or changing the flow insert for the oil inlet since one would cost ford more money they changed the oil.
http://www.repairfaq.org/filipg/AUTO/F_oil_facts.html
http://auto.howstuffworks.com/turbo.htm
The water cooling system is engineered to allow a process called reverse siphoning to take place. When the engine is switched off, the water pump ceases operation. The coolant in the extremely hot turbo boils and fresh coolant floods in behind it. This process continues until temperatures reduce, providing sustained, key-off protection for the turbo bearings.
“The EcoBoost engine uses passive thermal siphoning for water cooling,” Plagens explains. “During normal engine operation, the engine’s water pump cycles coolant through the center bearing. After engine shutdown renders the water pump inactive, the coolant flow reverses. Coolant heats up and flows away from the turbocharger water jacket, pulling fresh, cool coolant in behind. This highly effective coolant process is completely silent to the driver, continuing to protect the turbocharger.”
I asked my Service Mgr yesterday if he knew anything about the change.
His comments were that the 5-20 is PARTIAL synthetic while the 5/30 is Full Synthetic.
The 5/30 allows 10K mile oil change intervals. Customers appreciate that. His personal recommendation is go full synthetic but change every 7500. Or do the partial synthetic but keep under 5K oil changes
