Who has the most suspension mods?
AutoXSHO
Glenwood, MD USA
After seeing how easily the GTP rear arms adapt to the SHO, I will definitely have to pick up a set once I have a more promising financial situation. I don't see a reason to go to any other control arm than these.
I don't have nearly all the mods some of these guys have but the car still hustles around an autocross course.
JV
95 MTX
Tokicos/Eibachs/Solid SFBs/20.6mmFSB/26mmRSB
Need to do the strut rod bushings everywhere, and get those SFBs installed.
Black91SHO
Irving, TX
- IPT (koni 5-way) struts & coilovers
- Subframe connectors
- Gen 3 subframe mounts
- RCM lower control arms
- H-brace
- TPR and poly bushings all around
- Camber adjustment plates
- Gen 3 subframe
- 24mm fsb, 26mm rsb
- 17x8 BSA Racing Rage rims
- Hancock Venus S1 Noble 2 245/45/17
- Brake bias plug (helps handling while braking)
- Quaif (qualifier: helps handling)
- Cobra brakes front, big brakes rear (They're attached to the suspention)
The only things I'm missing are the STBS and adjustable rear sway bar--didn't know that existed.
Black91SHO
Irving, TX
Oh, hot damn... This thread is like 13 years old. Whoops! This phone app for forums needs to show the thread date more readily.
