Who autocrosses their SHO??
Mike92SHO
Mandeville, Louisiana USA
Went to my first Autocross today. Didn't run, just watched. However, I went around the course with my friend in his S-Trim equipped '92 notchback Mustang and I am hooked. Next time out I am going to run the SHO.
My SHO has Tokicos, and subframes but no other suspension mods. It has slicers and stock sized BFG Comp T/A VR-4s. I plan on upgrading the tires, but probably will keep the stock size and slicers.
Just curious to hear stories of guys/gals that have run their cars, how they did and what additional mods you would suggest.
Thanks,
Mike
'92 Emerald Green SHO MTX. SHO Shop Exhaust, Subframes, Custom Chip, K&N Panel, Subframes & Tokicos
'85 LTD-LX street/strip car. Fully worked 306, C-4, Gutted screamer. Low 12's at over 110 N/A with 8.4 compression.
fredhurderjr
www.neshospecialists.com
I started stock, added SFC's & 17" wheels first, then rear sway bar on my 95, then the blower, then the Eibachs, Tokicos, 96 brakes, and oops! Never got to run with the springs, struts & brakes! The blower kept causing me grief.
W
whelen1
Guest
Yes Eric, you did race Freds car....down the middle of the backside slalom!
ChrisR
Las Vegas, NV
I can't wait to do it. I was going to do it last weekend, but I just didn't want to get up at 3:00 AM to make it there. I hope to go to the next one around here.
ThrillSHO
Wake Forest, NC, USA
I’m also an Autocross addict. I started in ’94 with a Firebird and then started running my SHO in G-Stock in ’98. First, please spend $15 for a rulebook at www.sccs.org. Your fellow competitors will thank you for properly classing your car. Note that your SFCs bump you from Stock, past Street Touring, past Street Prepared, into Street Modified.
I ran G-stock in ’99 with mild success. G-stock is no place for the SHO now since cars like the all-wheel-drive, Turbo Subaru RS 2.5 have been placed there this year.
I ran E-Street Prepared in 2000 always finishing 3rd or 4th. The SHO can definitely be competitive here, but check the rules – many of our favorite mods are illegal (ie, SFBs, SFCs, coil-overs, big brakes).
I sat out most of 2001 with a broken tranny.
I plan on running Street Modified this year. This is a fun class because there are few rules. On paper the SHO looks weak because the class includes naturally aspirated cars up to 6.0L, but HP isn’t everything.
Most of all, get out there and have fun. The temptation is to buy the “hot mods” so you can go faster, but sticky tires and lots of seat time will yield the biggest bang for your buck.
ThrillSHO Racing
93 ATX SHO
UDPs, LPM, 80mm MAF, K&N w/CAI Snorkle, 8mm Taylor wires, Koni Struts, IPT Coil-overs, Camber plates, Adjustable rear control arms, Touque box brace, Poly bushings, 24mm front SB, 26mm rear SB, Shaved Alum SFB, Full-length SFCs, Front & Rear STBs, SS Y-pipe, Borla Cat-back, TransGo Shift Kit, Relocated battery, Five point harness, Five 2" gauges below the CD player, 225/50s on 16x8s, 96 Brakes
Very Low Very Fast
thebigjimsho
LSA = YUM
Worcester, MA, USA
Horsepower deifnitely isn't everything! I have a '92 with alot of the suspension mods but with few power mods. With roughly 235hp and BFGoodrich R1's, at my last autocross, I beat a couple SC SHO's, 2 Vipers, 3 Cobras, an older(89?)M3, and many more. The only car that beat me that day was a Boxster S with the same R1's that I had. And that was by .2 seconds on close to a minute track.
Mike92SHO
Well, I figure I am going to be in SM with the mods I have. Besides a set of Eibach springs and possibly some bigger brakes I really don't want to do too much more. I would like to run some stickier tires. I am not out to be a champion, just have fun. My buddy's S-Trimmed Mustang is in SM as well..that car is fast but the handling is much less refined.
I am also considering setting up my LTD to run in SM. It is currently more drag oriented but could easily be setup for Autocross. This car is the midsize LTD and a Fox platform car. All Mustang parts bolt on...the wheelbase is just a little longer. With 400 HP @ the flywheel and just about 2800 pounds it could be quite fun to slide around in. Another fast 4 door with a slightly different flavor.
I am going to try the SHO first though before I invest the cash in the LTD to make it run.
I am sure seat time is the most valuable asset in this sport.
Mike
Jibberish18
Chicago Il.
I wanna AutoCross. Where does all this happen?
1990 Sable 3.0
"My goal is to have the ultimate Sable in road handling performance"
AutoXSHO
Glenwood, MD USA
(See username)
I started Autocrossing in '95 with my RX-7 turbo. Found out that ASP isn't a fun class to compete in when you only have one competitor. I ran '95-98 in ASP, '99 in BP, finishing mid-rear pack at every race.
I have autocrossed the SHO two full seasons. I did one full season in (the old) GS aka the Type-R class. It wasn't for me.
Found STS last season at Akron, (www.autox.net) and have been having fun there. I think I did surprisingly well given the tires I was running and the small amount of time spent on alignments
Even when you're not winning, Autocross is fun.
John V
jprinesho
Jacksonville, FL
Definately a lot of fun. You'll safely find the limits of your car's handling abilities. And in this case, it's more the driver than the car. I autocrossed a 2000 Malibu rent-a-car (don't tell) and let Turbosho do a couple laps in it. He beat some kid in an Integra Type R. The differnt clubs usually try to hold driving schools 2 or 3 times a year. They are definately worth going to.
90 MTX Black/Black - Tons of mods - Previous SHO Shop test mule.
drivinhard
Gainesville, GA
"The temptation is to buy the “hot mods” so you can go faster, but sticky tires and lots of seat time will yield the biggest bang for your buck"
Absolutely, this is true for open tracking and drag racing as well. The right rubber for the right job, and lots of seat time.
Seat time is the best mod (usually pretty expensive to!) and it usually works out to be the most fun
mark
2 months till the toys come out, and lemme tell ya...LOTS of seat time on the calender for '02!!!
ChrisR
Las Vegas, NV
I did it today! It is absolutly awesome. Even tho the morning cars got to go in clear weather, and I got stuck with the pouring rain, it was still super fun.
Chris
DeaconBlue
Cleveland, Ohio
mark
Yeah right I think the "wife" may have something to say about that
95 MTX
with a few mods
AutoXSHO
Glenwood, MD USA
Right. By seat time you mean sitting next to Marisa in the paddock while the other John and I mix it up on the course?
John V
DeaconBlue
Cleveland, Ohio
Well of course !
You have to get the priorities straight. Marisa is a heck of a lot cuter than either you, John V. or John Heer. You won't want me to leave her alone with those Camaro or Corvette guys now would you ?
I didn't think so, hehehe.
95 MTX
with a few mods
