Ok, I just put my guages on today and I have a few problems. First of all my auto lamp isn't working at all, and neither are the lights that light it up or the lights for the manual headlight/parking light switch. Also, my whole cluster is screwed up. The speedometer doesn't work right, it kinda shakes as it goes up and doesnt go up very fast and it makes a little bit of a noise. Also my tach doesn't work at all, and my temp guage didn't move at all. It was a pain to do all of it, almost more trouble than it's worth. Any help would be great.
yeah it was like a tink tink tink tink and it fluttered then halfassed went up and would fall back down, did you mess with anything behind the gauge cluster? It could possibly be, but I don't think so. No problems like this before? with the other stuff check fuse, it could be that you need not pull the accessory wire from the lights, use the wire from the switch, that is the best place, you won't have to worry bout using too much juice then, the circuits will only take so much. If your fuse is blown then that may be an indicator, or you accidently grounded out the circuit
but anyway find the wire that goes to the switch, then sauder the wire into the fuse box, no worries then, do you own a multi-meter? a cheap one will do wonders for troubleshooting the electrical stuff on our cars bro, just ask beth. good luck, let us know what you find
