Which motor mounts?
rendyx
Buffalo, NY
We have determined that my motor mounts may all be shot, with my interesting mount test results left and ride side of motor lift up on tests). Having a Quaife, I am not sure if I should go for Josh's reinforced, or Extreme mounts. And thoughts?
rendyx
Buffalo, NY
Josh is SHONUT (and makes extreme ones). I currently have SS ones, but a little Tq limiter problem caused a motor mount problem.
SHO--ripper
928 Euro
winsted,CT
I'd say go with the extreme.
Also, did you sell your SHO yet. If not i may have a friend who would want to buy it... That is if you'd be willing to drive to CT.
SHOTerror
Orange County, CA
Wait a second... Quaife= more strain on mounts? I thought this was a step in the direction save items such as these and *cough* dif pins?
<small>[ May 23, 2003, 02:56 AM: Message edited by: SHOTerror ]</small>
Blue-By-U
CT
Personally I would go with the regular sho nut reinforced mounts. I would use the extreme only if I supercharged my engine or had nitrous.
Bizzy
LL-Cool-A:
That's also what I suggest to Pat last night. I believe with his quaife that reinforced mounts are in order, but I think the extremes would be overkill for his particular application at the moment.
yamahaSHO
E85 whore
Arkansas
Pat,
I have been thinking which ones I should get myself. I first wanted the regular SHOnut reinforced mounts, but now I am leaning more towards the Extreme mounts. If you still want to run your solid torque limiters, I would suggest the extreme mounts.
