Which gauges are needed for Nitrous?
Speedy_91_SHO
Toledo, OH
I already have Volts, Oil Pressure, and Water Temperature. I am putting Nitrous on over the winter and I was looking over gauges. I think I need to get an A/F gauge, Bottle Pressure, and Fuel Pressure. Midwest SHO says a knock sensor is a good thing to have when using nitrous. I will have 6 available holes for gauges which gauges should I get. Thanks, Chris
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
I recommend a Wideband Oxygen Sensor controller and Gauge. Fuel pressure is a great idea also. A knock monitor is a good idea.
Bottle pressure, you can keep mounted to the bottle to free up a gauge slot if needed. I know that car has a 3-gauge pillar, I'm assuming you're putting the other 3 gauges under the radio. I would keep the Oil Pressure, AFR, and Fuel pressure up on the pillar. The knock monitor probably doesn't mount in a 2 1/16" hole, so that leaves you with one extra hole to fill. Lets see:
-AFR
-Knock
-Oil Pressure
-Water Temp
-Voltmeter
Bottle pressure, Vacuum, Oil temp, Trans Temp...
What do you plan to do with the car? Any road racing? Or just drag racing?
MilTownSHO
Horicon, WI
AutoSHO said:
Any road racing?
If you mean road racing like auto-x and road coarses I sure hope he does, I know the car is built for it and is a blast to do (speaking from personal experience of course :p )
But I think he's looking more into drag racing :thumb:
Speedy_91_SHO
Toledo, OH
I plan on doing mostly drag racing with maybe an auto-x or road course here or there. Like the convention and such.
I am actually doing something custom for mounting the gauges. I'll have pictures when it is done, I think it'll be sweet. Thanks for the info on the gauges, I have to do some more looking. What does a knock gauge do exactly? Does it sense detonation? Also, it volts really necessary? The Wideband Oxygen Sensor Controller and Gauge is the AFR correct? Right now I am thinking AFR, Oil Pressure, Fuel Pressure, Water Temp, Bottle Pressure, Knock.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
My voltmeter has kept me from getting stranded 3 different times... I wouldn't go without it.
crystizel
