Wheres the remote keyless sensor located?
SHO SPD
SHO member #480
Naples, Florida
I want to convert an after market remote to the original remote, working the aftermarket features, but wheres the sensor located at for the factory remote?
halfasspunk
Hinsdale, IL
what does this sensor look like? my keyless entry is not working and there is something hanging around in my trunk. is the outside temp sensor also in the trunk?
yamahaSHO
E85 whore
Arkansas
I have not seen my SHO in a while, but if I remember correctly, it is a black box mounted to the back of the back seat on the drivers side. I will see if I can find pictures of the trunk and then post them.
Off Road SHO
Moderator
The receiver for the keyless remote is in the trunk. It's usually mounted to the drivers side fender well, behind the carpeting.
Tom
Tmade
Cincinnati, Ohio
I went through that battle too, on the Gen II the remote sensor is on the back of the rear seat on the drivers side. There is a divider that covers it up, usually some form of cardboard, you have to pull it back a little so as to see it. thumb
If your trying to reprogram a new fob for keyless entry, e-mail me at @ [email protected] and I'll send you the pictures I took of where that connector is actually at. That connector is actually in the drivers side REAR wheel well, that is accessible from the trunk, you just have to pull the lining back a little...like I said I have pics for ya if you need them.
Tmade
laughing
thatSHOguy101
