Where is the tranny cooler lines located?
Snow
Scranton, PA
Where are the tranny cooler lines located?
I have my front bumper off I see the radiator, then the ac condenser, and then another cooler (looks like it is hooked up to the power steering). Where are the tranny cooler lines? I bought a B&M cooler and want to install it..
SuperG
Houston, TX
Well, it should be really long and short and is the first thing you will see in front of the radiator at about the height of the bottome of the license plate (I think). Some folks install the B&M on top of the stock cooler...
Mr Anonymous
Tire Wall
Unless you have a mid-98 to 99 SHO, the tranny cooler tube will be the higher of the pair of tubes in front of the condenser, and is the one without fins. Yup, that's your stock cooler. Pretty impressive, eh? The lower finned one is the P/S. On some mid-98's and all 99's, both tubes are finned, but the upper is still the tranny cooler.
The PS cooler is on top and has a 1/2" hose. The ATX is below it is for the ATX and has a 3/8" hose.
Or you could connecty it betweenm the radiator cooler return to tranny hose. This is the hose connected to the steel line under the radiator.
