where is the plug that I need to short so that keyless system is set to program??
gentlejax
Shreveport , Louisiana
I need to program my remote...wheres the plug that I need to jumper so that the system goes into program mode so I can program the remote....
Mike
SASHO91
Zoom Zoom
San Antonio,TX
Under the carpet in the trunk, around where the Inertia Safety switch is.
( a search would have shown this)
gentlejax
safety inertia switch is mounted on the side of the fenderwell......I lifted up the carpet and didnt see anything much less a plug...I saw the safety switch
now are you saying its under the switch down on the botom of the body? or what? I did search for it under the carpet but didnt find it..I posted in another forum and didnt have time to re-type all of the post here....
SASHO91
Zoom Zoom
San Antonio,TX
It might have moved around... but it should be mounted to the inside of the fender. Its a grey two-wire plug. Its gotta be on that side, somewhere...
You do have a 93+SHO right?
gentlejax
I have a 95 SHO....I will look for a grey plug...it will need to be unpluged or is it not attached? I might have seen it but it was plugged in to something else...I will look for it again now that I know its a grey plug.....any idea what color wires are on it..? just trying to narrow it down before I go shorting something out..
SASHO91
Zoom Zoom
San Antonio,TX
the plug is not connected. I cant recall what color the wires were, but the write-up on www.shotimes.com may have them.
It may have popped off the fender (it has a push-in clip deal) and is probably hanging down toward the bottom. Another possibilty, someone could have relocated it, but that would most likely put it towards the back seat area(where the actual module is).
