Where is the Low-Side AC fitting?
kumba
Tampa, FL
OK, I know I am going to feel like a dumb-ass as soon as someone answers this question, but where the **** is the low-side AC fitting?
I see the high-side near the battery, but cant find the low side. It's either buried (like most things on this car) or there isn't one (weird?).
Thanks for the help :)
hawkeye18
Sorta cares
Norfolk, VA
If you have an ATX, the low side fitting is on the passenger side of the firewall, behind that plastic cover-looking thing. You need to pull out the plastic push pins retaining it and lift the cover up. You'll see it to the left of the dryer/condenser (looks like a flask with a plug on top).
If it's an MTX, I have no idea. Sorry. lol
shotime1994
AirHammerAndrew
New York
Under the cover that is on the firewall. It doesn't matter stick or auto.
kumba
Tampa, FL
Well, that would explain why I couldn't find it, I wasn't expecting it to be shrouded.
On a related note, what are the nominal pressures for the AC System on a '95 ATX? It's been a while since I've messed with AC, but I want to say the high-side scale ranges from 2.5-times ambient temp (in F) for the low end and add 10% for the high end. The low side I want to say should read about 25% of the high-side. All of the above ratings are for the car when at 2500-rpm, and the low-side needed to be above 25-30 PSI to activate the pressure switch.
So if it's 80F outside, my high-side should read between 200 and 220, and my low side should be between 50-55psi. Right?
Since my guages and jug of freon have dust on them, I also wouldn't mind someone who's kept up with it to correct my memory if possible :)
projectSHO89
SHOless In St L
