Where is the inside temp sensor
jdksho
Virginia
I have a 94 ATX and want to locate the automatic temp control sensor so that I
can remove the dust from it. Any idea where it is located? I'm at a loss as to why the outside temp reading is 30 degrees off and want to eliminate this as the culprit. I have replaced the outside ambient temp sensor with 4 or 5 different sensors and even tried a couple different EATC units with no luck yet.
