Where is the F*&$ is the BP Sensor at??
It's back against the firewall around the middle of the car. Mounted up near the lip where the weather stripping runs across the back of the engine bay. It's kinda rectangular with an electrical connector on one end and an open hole where you might think a hose would fit but there isn't one.
<small>[ December 04, 2002, 07:14 PM: Message edited by: luigisho ]</small>
projectSHO89
SHOless In St L
It's actually referred to as the MAP (Manifold Absolute Pressure in the 89 service documentation) or the BAP (Barometric Absolute Pressure in later years).
Ford used an existing manifold pressure sensor and just left it unplugged, allowing it to mesure barometric pressure.
Luigi's description is dead on.
Steve
philallemang
Clearwater, Nebraska
ok.....not for sure which one it is. Is it the one with the 2 wire connector or the the one with three? iam sure its the little with one with the 2 wire connector but i want to make sure
shobroooo
