Where do these connectors go? 95 mtx
henthcr
Wisconsin
I am reassembling my sho after removing the subframe to replace the transmission, well like an idiot, I unplugged everything and didnt label everything, now it wont start and I cant find where these go.
the first one is by the windshield wiper motor.View media item 247the second one was just hanging under the car when I took everything apart.View media item 246the third is on the wire with the eec test connector.View media item 245and the last is on the antilock brake test line. View media item 244
any help would be great
henthcr
Wisconsin
so if anyone sees this and is also confused by something similar , i figured out that the third one is something something a/c clutch and i had it grounded oddly, it is on the front of the a/c compressor, and the 4th one is a ground connector for the testing block. the first two are still mysteries to me.
kevinspann
Don't take my advice.
Richmond VA
Is the first one the plug that goes into the brake reservoir cap for the low fluid sensor? If not, it may be "nothing".
The second looks like the temp sensor that screws into the heater core hard pipe (if you still have it). The temp sensor is for the auto climate control and wouldn't effect engine running.
Three, you're spot on, that goes to the AC compressor to power the compressor clutch.
Four, glad you found it because I couldn't identify that.
shootinirons
