Where do I find the CTS ?
reags8
Connecticut
Get to it from under the car I presume ? and what is IIRC ?
Remember I'm a juniior member.
Scott
SilverSHO
cartersville
IIRC = If I Recall Correctly
The coolant temp sensor is right next to the thermostat; it's under the throttle body and has a single wire attached to it. I got one for about $3 or $4 at Advance.
yamahaSHO
E85 whore
Arkansas
If you are talking about the ECT(the sensor for the PCM), it is just to the right(towards rear of engine) of the t-stat housing. The one just to the left is for the temperature gauge. You can get to the ECT from the top side with the intake on, but it because quite tiresome reaching in there. There may be a big wire bundle in the way preventing from easy disconnection and removal. Also, you may want to remove the intake tube leading to the throttle body. Good luck!
bmytych
