Where can i find
Fudog
Sac town CA
Ok so Im going to upgrade the SHO's audio now. I would like to know If I should bypass the amps and run my own speaker wire. Or should I get the wiring harness. If I should get the harness where can I buy it?
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
Why would you run your own speaker wire? Your car should already be wired from the head unit directly to the speakers bypassing the amps. The connector to do this is inside the DIN area...should be towards the drivers side. There is a little clip that holds it out of the way I believe.
I would use that connector to connect your aftermarket HU directly to the speakers.
SW SHO
Boss Man
Santa Fe, NM
You can get the connector to wire up aftermarket H/U at Wall-Mart for like 10 bucks. Schosche and Metra brands are more common. The black is for the speakers and the grey is for everything else.
I just did mine and it was really easy. The extra connector in the DIN area looks plugged in, but it's just a holder for it.
60kmaintenance
U.S.A.
How about running RCA's from the deck to the back then speaker wire from the amps back to the front, and power cables. My deck doesn't have an internal amplifier any ways, regardless even if it did I would never use it, they suck.
