jpeck2
the past 2 days when I start the car it either stalls or goes to stall... is this the battery or what?
No, if it were the battery it would not start.
Does it rev up higher after starting, say to 1200 rpm or so?
The oil and alternator lights coming on when it dies is normal. This is because the alternator quits turning and the oil pressure drops because the engine stops turning.
If it runs when the throttle is cracked then the IAC is either bad or dirty or stuck shut.
