Wheels not turned the same angle
rendyx
Buffalo, NY
I've noticed this...my front wheels are not turned at the same angle. Example: when the steering wheel is turned a little and I go to look at the front wheels, the driver's side one is, say 10 degrees from the fender, while the passenger side one is about 15-20. It's a fairly obvious difference. Any thoughts?
pjtoledo
'ol man in the SHO
toledo,ohio,usa
That is exactly how they should be. When turning, the inside tire follows a circle of smaller diameter than the outside tire. So, the inside tire has to turn inwards more.
Perry Toledo,Ohio
rendyx
Buffalo, NY
Cool, based on that, it's fine. I make a final turn to the right in my driveway, which is where I have noticed it, and the inner wheel for that turn (passenger) is always turned more. Thanks! :)
