Wheel Requirements ("Will Mustang Wheels Fit")
Yamaha V6
SHO Enthusiast
Rhode Island
The SHO uses a 5-lug, 108mm bolt pattern (~4.25").
The (5-lug) Mustang uses a 4.5" bolt pattern.
Out of the box, Mustang wheels will not fit on a SHO.
The stock '89-'90 "Basketweave" wheels are 15"x6".
The stock '91-'92 non-directional ("Canadian") slicers are 16"x6", as are the stock '93-'95 directional ("Italian") slicers. They use a +42mm offset.
(insert Gen 3 wheel info here)
Various wheel combos have been used, some more successfully than others. 16x7, 16x8, 17x7, 17x8, 17x9 (w/ spacers), 18x7, 18x8 & 19x? have been used. Offsets typically vary from ~+37mm to +45mm. On '89-'91, the rear fender flares may require fender trimming on oversized wheels, as does the occasional '92-'95. (insert Gen 3 fitment notes here).
Tire widths from 205 through 245 are commonly used on the oversized wheels (215 is ok for 6" wide, 225-235 is typically 7"-7 1/2", 245 is typically for 8")
Some Volvo wheels, some Jag, some Lincoln, some Thunderbird wheels will fit. Here's the meat of the subject though: "5x108mm", "offset between +37mm & +45mm" will get you very close, but individual test-fitting is always best. "Your Mileage May Vary".
cmichaelo
Gee, Ollie!
New York
FWIW, I have a Gen2 on which I'm using 18x8.5" rims with a +42.5mm offset.
Tires are 235/40-18.
In the front there's about 5mm clearance to the OEM strut housing.
In the rear, I use 15mm spacers to push the wheels as far out as possible for a nice wider look (and better handling). The fender lip is totally removed. I shaved it off all the way around. Even part of the side skirt plastic molding was taken off to prevent rubbing at the fender near the rear door. I had to relocate the screw that holds the side molding in place inside the fender.
The spacers are custom made by a machine shop. They are hubcentric and fabricated in alum. If you're interested I'll send you drawings.
There is no rubbing front nor rear.
The car is lowered by 1 to 1 1/2" (Intrax/Koni).
Michael
