mrgrim333
What would you say is a reasonable quote for a front left wheel bearing replacement and repair for a 91 MTX?
If you dot it yourself - Rockauto has the parts by timken for 50-55 dollars depending on when in 91 your car was manufactured. It's not hard to do you just need a few tools. It takes me about an hour to do one - so at a shop rate of 75 dollars an hour plus your part ----- A shop would probably be about 130 dollars per side.
While I agree that Timken generally makes good bearings, my experience (and several others that I have talked with) on Timken bearings for the front of the SHO is that they are junk. In my case the Timken one lasted 3k miles, and from what I've heard that's a long time for that Timken bearing. I would buy anything but Timken for this application.
