Do it like Ocnaj already said, everything on the TB and intake must be capped off. The engine block valley PCV hose must be vented or routed to the catch can. Same for the valve cover. You can't put the catch can inline with the TB inlet's, even with a check valve, it will blow the oil right back out when it pressurizes.
I never had the factory fuel pressure regulator on long enough but it should be on the intake with clamps, but I wouldn't hope for much fuel pressure regulation once your into boost, I highly doubt its a 1:1 system. You have to go with shonut's aftermarket with its vacuum line routed directly from the intake.
The butterfly actuator vacuum should be routed to the intake but you may need a check valve so the canister doesn't pressurize. A turbo guy may be able to answer this better. Same for the evap purge line, must be in vacuum or blocked.
The brake booster should already have a check valve right before it but I highly doubt it will hold boost pressure for long, some boost will creep past it and your brake pedal will go rock hard. But at first put it where it is now w/ the check valve, take a few road tests, if it doesn't stay under vacuum then someone maybe able to answer this better. Not an issue for us S/C guys w/ the TB before the inlet of the S/C.
Venting it stinks and it always seems to come inside the car, I just deal with it. A catch can should help but it still stinks. But its better than it going in the engine, it lower's your octane and puts a nice oil layer inside your intake.
