SASHO91
Zoom Zoom
ok i have gone through 3 pairs of rotors up front. the first time i had to get new, calipers, rotors, and pads. the rear just got turned along with new pads. that was $550. plus some other stuff. Labor was the real killer though.
then i went through those. warped them and cracked them. then when i went back they put new ones on, with new pads.
then those went to crap. warpped these, so they just turned them. And new pads.
then those did the same thing. this time they told me that i needed to get new struts because that was the problem. so i did. put new struts on, and upgraded the rotor from the regular, to a better one, and put ceramic pads on as well. this was another $300. mainly for the strut install.
this has lasted me for a while, but a couple of days ago i noticed that it was acting up. so i checked the rotors, and sure enough, my side rotor on the inside is allready grinding.
this is really starting to **** me off. so I am going to be doing the 96 upgrade, but for now im going back to midas to get them to fix this s***.
And the rotors and pads i had on there were awsome. no fade, and stopped pretty good. But i guess the undersized rotors just suck!
So as i have gathered, the 96 upgrade contains for the 11.6; 94-95 knuckles, 96+sho caliper brackets from junkyard or ford, rotors, and pads.
what else am i missing?
How much will this set me back?
i know that i should have done this in the first place, but parents payed for it the first time, and they wanted it to be profesionally installed, and under warrenty.
But if i knew then what i know now, i would not have even bothered with midas.. **** for the money i have spent on brakes already, i could have got one **** of a setup from midwest... live and learn...
P.S. I hate Midas.....
Anyways, i told them about the upgrade that i was gonna do, and the said that instead of fixing this problem, by putting the new rotors, and pads, back on, to just bring the parts for the 96 upgrade in. and they will do it. i was like yeah that will come out to like 500 bucks! yeah right. I can do it myself.
