Initially, I thought this blowing whistling noise was coming from the valve body as what I was told, but I've since had a tranny rebuild, and this noise is still there. Actually, the noise is more pronounced from inside the car as the engine is running. But, you only here this noise when you apply some gas, whether in park or driving.
It is barely audible from under the hood, but it seems to be coming from the passenger side, kind of down by the accessory belt area. Don't think it is an accessory belt type noise. Could be some type of vacuum leak, but I don't know what vacuum lines if any are located in that area. I know I have a busted a/c compressor, but that's been out for two years, and I've only noticed this noise for like 2 months.
Hope this is somewhat clear; anyone have any suggestions on where I should search for the problem, let me know!
