What should I replace with struts and springs???
ArrestMeRedSHO
S. Windsor, CT
When I replace my struts and springs is there anything else that is recommended to do at the same time? Just curious since I'm getting ready to have the work done I figure I'll do everything at once.
1993 MTX Red w/black int
ShoShop Stage 1
Yokohama Avids 215/60/R16
WaterRooster
Here
Look at www.shoshop.com
They have a suspension support package. It basically covers everything in there.
Shawn
93 Emerald Green MTX
CAI,PP Y-pipe, Dynomax Catback, 80mm MAF, LPM, Ebachs and Tokis
rlw001
Reading, PA, USA
Call Josh or Nick ar SHO Nut Performance, that is what I did. They most likely will advise on strut bearings, mounts, various bushing, bolts. Many items are in kits which makes it much easier.
Bob W
94' ATX, SHOshop Y-Pipe, SHO Shop UDPs, 70mm FPS MAF, SuperChip,
K&N Panel, Coneless, 96' Brake Upgrade, Colgan Bra, PIAA 1552 Driving Lights, Eibachs/Tokicos, 24mmFSB, 26mmRSB, Subframe Connectors, 17x8 TSW Hock Rs, 225/45/17 Bridgestone RE040s, 255lph Walbro Fuel Pump.
RStalveyARFF
too many shos
Georgetown, MA
I'd get anything that involves removing the strut and spring, bearings, plates, I'd go for the eccentric front plates if you can find them, that way you can add an STB in the future and adjust alignment on a whim.
philw349
PhilW
Tucson, AZ
I didn't see a phone number for those guys. I think they're email only. I might email them though I've got similar work to be done.
poffffd
