SaltyDog
Hat in hand here…I’ve screwed something up and ask for any/all sage guidance you might have.
Facts – 95 5-spd, 170k miles; chip/80mm MAF/hi-flo y-pipe/underdrive pulleys.
Car was running good but had an annoying stumble @ ~1800rpm. Discovered oil in #1 and #6 plug well, so I decided to do a pre-winter tune-up. Oil & filter, coolant & thermostat (192), plugs, cam sensor, valve cover gaskets & plug well gaskets, and the barometric sensor (that thing in the intake tube prior to the MAF).
End result – no more stumble @ 1800 rpm, car runs great – but mileage is in the toilet! Went from 25-27 down to 18-19! What have I done???
I went with DENSO plugs this go around (vice autolites), I’m thinking this may be the culprit, but haven’t read about anyone else having this problem. And if it hates the DENSO plugs that much, wouldn’t it run bad? It is a little hard to start now, cranks more than it used to - but once it is started, it runs fine.
I just pulled codes:
KOEO – 511, 114 (pause) 542. Ran it again, and the 114 didn’t show.
KOER – 111. Also ran the cylinder balance test and came back clean (9).
Thanks in advance.
Brian
Thanks in advance.
Brian
