What fluid should I use in the Transfer Case/PTO?
Bullitt5094
Austin, TX
I am about to do the first change in the Transfer case (PTU?) on my 2016. I'm sure there is a fluid recommendation in the OM but is there a recommendation of any superior gear oil from the experienced users on the forum? Any suggestions would be greatly appreciated.
Joshw0000
North Carolina
What I use:
RDU - Royal Purple 75w90
PTU - Royal Purple 75w140
Sent from my Pixel 8 Pro using Tapatalk
Florida
Ive heard motorcraft is a safe bet, RP is always a good choice from a solid company, but I second @SM105K suggestion, he wrote the Bible on maintaining these cars. Myself and others have felt a noticeable difference in the car with the lightweight shockproof.
I have no experience with any other fluids to compare and while we use different fluids, we all agree the service interval is the most important with what ever fluid you use. Have fun, and if it's not a PP car remember to breathe.
Bullitt5094
Austin, TX
Mine is not a PP car so I'm a bit puzzled at this response.
Also is there a good source for the Redline that SM105K is recommending? I don't see it on Amazon. And what is the capacity of the transfer case? If there is another thread covering all of this, I haven't found it so sorry if this is all redundant for the forum.
FREAK_SHO
Wisconsin
Mad -scientist's way of sayin' the non PP PTU is not quite as "easy" as the PP PTUs
Florida
It's been covered but I too have a non pp car and have recently done this for the first time myself. The pp cars have a drain plug, the non pp cars only have a fill plug which means you have to suck the fluid out of the case which can be frustrating and time consuming (hence the breathe comment). It is recommended to use a vacuum pump, I used one that I used for brake bleeding, same thing literally. Some prefer the syringe method but what ever you prefer.
Can't say for sure on capacity but 1 bottle will probably do the trick since you won't be able to get it all out. Usually it's recommended to pump out as much as you can, run it for a few miles, and repeat 3 times, this gives you almost fully fresh fluid.
As for a reliable source for lightweight shockproof, I'm told it's a smaller company and it's not always easy to find. I suggest when you do find it get 4-6 to have some stock.
Zpak
Es Aich Oh!
The region, Indiana
Non PP without drilling and tapping a drain plug you have to suck out the fluid and pump back in through the fill plug.
As for fluid, redline lwsp all day. Smooth as silk.
Joshw0000
North Carolina
Things you'll need:
A way to get the car off the ground. I like to use ramps in the front, jack up the back, and put stands under the back. Try to get it as level as possible.
Lots of socket extensions (unless you remove the front right tire) to get to the PTU fill plug. See the above comment for why I do it this way. Harbor Freight for the win.
A low profile ratchet to get to the tight space to remove the RDU plug (or cut off the unused exhaust bracket). Harbor Freight also has a cheapo that works.
A fluid extractor. Something like this works great - Wzyblixo 6.5L Oil Extractor - Pneumatic/Manual Vacumm Fluid Extractor Fluid Change Pump with Extended Oil Suction Hose and A Brake Bleeding Hose for Automotive Fluids Vacuum Evacuation https://a.co/d/g26qh5A
A pump to push the gear oil back into the PTU / RDU. Something like this is good - Slippery Pete 5cc Hand Pump Transfers Gear Oil, Transmission and Differential Fluids From Quart Bottles (Not for Red Line Quarts) (1) https://a.co/d/2hLGlGk
These are just random links I found on Amazon for reference. You can use better or cheaper pumps.
PTU - one quart is fine, RDU calls for 38.4 oz. As mentioned, you won't get the full amount in or out so one quart should be fine as well. Suck out all you can, fill until it overflows and put the plug back on with a little bit of thead sealant.
If needed, I'll see if I can find an old post from my first change.
Oh yea, you can always get Royal Purple on Amazon.
Bullitt5094
Austin, TX
OK. That makes sense. Maybe I'll drill and add futomo valve in there as I have in several places on my 6.0 Powerstroke. I did purchase one of these Thing that sucks so that should work if i don't go the additional drain hole route. And I do have a two post lift so working under the car is a LOT easier.
Bullitt5094
Austin, TX
Things you'll need:
This is very helpful. Thanks! You were posting this as I was posting the reply above.
Joshw0000
North Carolina
No prob. You have a lift so you can ignore half of what I said, lol I'm sure you're fully capable of doing this service.
Bullitt5094
Austin, TX
What you show linked there is not the Shockproof Lightweight oil I thought everyone was describing. Isn't this what I should use in the transfer case? I want to be sure I'm attempting to track down the correct product. Redline Oil
kryptto
South East, Florida
thats it - however there are threads where redline has been out of stock for a while. nothing wrong using the what's right for my car, and using a product in stock. unless someone posting here can suggest a redline product not out of inventory
PS - I sent an email to the company - lets see what they say, will report back once I hear from them.
Bullitt5094
Austin, TX
I certainly can't find it. I'm likely to get RP and make this initial change since I can grab it today. I'll run that for a while and just change it again with the RL if I can find it. The car is @ 70K so I'm thinking it's overdue from what I've recently learned here.
Joshw0000
North Carolina
Yep, it needs to be done but you're not in too bad shape. You can do your next change in 15K miles, then go to 30K miles after that.
kryptto
South East, Florida
35/k miles - it will look like graphite grey - make a change 15k later, then every 30K
