PMD Power
my SHO seem to be pulling form side to side... like a contsant tq steer... but it alternates sometimes... is this a sign?
Ditto... Usually when the diff goes out you will know.Bizzy:
Sounds like the signs of bad subframe bushings to me.
Yup...clank, clunk, clink...puddle, puddle, drip, drip...Mikeys_Taurus:
Sounds like the signs of bad subframe bushings to me.![]()
Yup... it would feel exactly like that.SHO_ROLLER:
Would it feel like the engine is moving back and forth when you let off the gas with bad subframe bushings? I just replaced the motor mounts.
I know this sounds dumb... but with it mounted that way it doesn't move at all... I wonder if it is bent or something? I mean it was like that ever since the previous owner had the clutch replaced by Ford.....jthomas68:
If there is a gap,your subframe is just floating on air.The stock mounting bolts are pretty weak as it is,i`d be nervous of driving the car that way.Also,if the bushings aren`t tight,the frame can`t be aligned,so you`ll also wear your tires.
Well that's part of the problem. Seriously though, don't mess around with the subframe. If it's loose or the bushings are bad take care of it. I can attest to what happens when the subframe drops (Ford installed one of the recall plate nuts upside down on mine) and it's scary as ****, not to mention dangerous.PMD Power:
The torquing that we saw when my 60k was done was a twisting type of movement. Pretty scary too, just ask Huntervf...he said he'd never seen anything like it before. It twisted so much that it put rub marks on my DIS which we originally thought was from a bad motor mount. But it was all the SFB. I believe if you see any movement, it should be very, very, very (get the point?) slight if any at all.dkautumna:
When you turn the steering wheel side to side, should the motor be totally still with absolutely NO movement? Mine moves side to side a tad.
