shomanv6
7000RPM
I just recently replaced my dis module that my mechanic told me needed to be replaced.before my car would surge at steady throttle on the freeway.now it doent do that anymore and the mechanic said he cleared the codes and everything is fine.ok,so i pick the car up as they were closing and when I turned the car over is took longer than normal to start,then when it started it had a wonky idle and wood rev up and down between 0 and 2grand on the tack?I was like wtf.so I talked to the mechanic and he said just drive it see how it does.so now the thing comes up with a crank pos sens code,and intermitantly the cel will come on and the engine will fumble till the light goes out.they already replace the dis module,the o2 sensors when they put in my new y-pipe,decarbonized the hole intake trac:throttle body maf intake runners the works,now they want too charge me more should I take it to someone else cause every time I take the car there they fix one thing and then something else happens.think there full of it! what do you guys think?
now I am pretty much broke and I have a bunch of good exhaust stuff and a hd clutch but the car is running like a pos.I really love these cars tho,its weired I have always been into cars and the ones that I own but this car is special it hits redline fast and is comfortable,but it seems to be a maintnace nightmare.thanx
