OSHSHO
Well, I bled the brakes...AGAIN...and still have the same problem
. The drivers side rear is dragging. Should these drag at all when new, or is this a sign of a bad set of slider pins??
The passenger side is not dragging at all. It is working however, or at least enough to scrape the surface rust that accumulates overnight.
SO...Which side is normal?? Which side is the concern?? Is there a happy medium? Thanks!
