Welded V8, Solid limiters, D4U1, ATX trans cooler, more
oldsho
Des Moines, Iowa USA
List has been updated, sfb's have been sold. Hood sale is pending, y-pipe is most likely gone. That pretty much leaves the quaife.
93_SHO_FL
Tampa Bay Area, FL
Do you have more Y-pipes w/ cats in good shape for 93 ATX? Someone replaced my cats with frickin flex tube!
PM me if so.
Thanks.
Wht91+
93 Green MTX
Oconomowoc,WI
Fast shipping, awesome communication. Great seller. Definitely would buy from again. Thanks Greg!!!
tompumped
VT
I'm curious if that car had clutch issues. I just had to pull my trans because the clutch was slipping if I shift as fast as I can into second or third. It didn't do this with my other flywheel. I also had it resurfaced.
I think I didn't wait long enough for the break in, but I don't know. Maybe I didn't grid the dowel pins down far enough so I just ground them more. I just don't want to put it all back together and have the same problem. I might switch out flywheels, but I don't want to.
oldsho
clutch
Unfortunately, I never drove it far enough to know, but I do know the previous owner drove it quite awhile before I got it and it was fine for him. Sounds like the pressure plate's not grabbing all the way down on the disc, so your theory on the pins may be correct, especially with the resurface.
