weird noise after long right turns?
svtC_and_SHO_Owner
Oregon
the sound has happend two times. after the same turn going to school. it seems fine after the turn too, but the next time i turn (left into parking lot) i feels "unalighted" for a second. then when i turn left again to park i heard a pop kind of sound. then when i leave school it seems normal, after trying to hear the sound by turning left and right circles. its not the engine, im thinking maybe a cracked sway bar? im pretty sure its next the front driver side tire. maybe power steering? i dont know. i guess i need to have les shwab take a look. they put in new shocks, struts, and tie bar ends in recently. its happend before and after i did this. so its none of those things. thanks guys
OSHSHO:
I had the same problem...I believe it was the Torsion bar bushings.
What!? Do you mean sway bar? Only some four wheel drive trucks still employ torsion bars instead of coil or leaf springs.
I would check the sway bar end link bolts (top and bottom), sway bar subframe mount bushings, tie rod end, inner tie rod joint, wheel bearings and subframe bushings. Other than that, it could be a worn strut, worn upper strut mount or even loose upper strut mount nuts. It could be any of the above or even something I didn't list, but you will have to inspect to locate the source. Good luck.
svtC_and_SHO_Owner
Oregon
les shwab couldnt find anything wrong. they said its probably a bushing. i kind got mad at how unhelpful they were.
