weird EATC temp reading
SinisterSHO
Rust free
630, IL
So, the other night it was raining pretty heavily and I was trying to go somewhere, but ended up coming home. Drove thru a couple of deep-ish puddles. Nothing more than 3-4 inches deep so nothing should have really been submerged. On the way home I press my outside temp button, and it says 0 degrees, tried later and it said 1. later that night it was -1 and -2. Today on my way to work, it said -27 then on the way home it said -40.
Did I short something out? what would cause this to read funny? Everything else still seems to work. (other than my a/c clutch being bad)
hawkeye18
Sorta cares
Norfolk, VA
...or replace it. It's right in front of the radiator (sorry, AC condenser) and is pretty easy to replace. Cheap, too.
SHOOFF13
SHOOFF
Massachusetts
Everytime I go to check the outside temperature in my 95 atx it actually reads -40. How can I fix that problem? It always worked fine until I had my radiator replaced a couple of weeks ago because it was leaking due to holes in it. What is the name of the sensor/part that needs replacing and how hard is it to install it myself? Any help is appreciated.
