Weird Centerconsole/climate control problem
deltch
Texas
I took my SHO to get the PTU/RDU fluids changed (still under warranty), immediately when picking it up from the shop I found that my climate controls on the center console weren't functioning and the defrost was stuck on full blast 90 degree heat.
Upon having the mechanics reset the battery for 30 seconds and check for bad fuses everything started working properly again
Has anyone ever experienced this before or know what might have caused it? Thanks
stripSHO
Idiot Savant
Detroit
I had this happen about 2 weeks ago following a dead battery and jump start. Pulled fuse, reset, problem solved. I wouldn't read too much into it.
stripSHO
Idiot Savant
Detroit
If it persists maybe get your battery checked. Mine was definitely trashed and I replaced it.
