Weatherstrip replacement
Deathacus
Pennsylvania
Hey there! Can someone help me find new front door weatherstripping for my '94? I bought one from SHOsource, he's generally been pretty good but the one I got didn't match, it was missing the textured interior portion. I also wanna replace the trunk seal and I'm afraid of getting another bad one.
BaySHO Performance
SF South Bay
Trunk Seal, Fairchild F3024:
Clicking on Jim's link brings up a Carid web page that contains two Fairchild part numbers, neither of which is the one Deathacus is looking for (front door seals for a 94):
F3022 is a front door seal for the Gen 1s. I installed a set on a client's '91. Won't work for a Gen 2. Purchased from Rock Auto.
F3033 is a rear door seal for a 94, not a front. Those are also available from Rock Auto, but they don't list a front. I also looked at https://fairchildindustries.com/products/automotive-products/door-seals themselves. They don't list a Gen2 front, either.
So I don't know what the Fairchild part number should be. OEM PN was F4DZ5420709A. None left in dealers inventory. None on eBay, either.
BaySHO Performance
SF South Bay
F4DZ-5420708-A jives with what I have for the right front. The left front is F4DZ-5420709-A. However, I've successfully installed aftermarket weatherstrips on both doors with the same part number. Those are interchangeable between doors. So I wonder whether oem are also interchangeable between doors, even though they have a different PN. Can't find an aftermarket one.
F4DZ5421453A isn't a door seal.
JRA2000TL
The Complainer
Daphne, AL
Thanks for the OEM part #, Nick. I'm looking myself. Driver door seal pulling away at the top of the B pillar curve. I have a nice puddle of water in the center of my floor pan only around the AC duct under the driver seat. Working on getting that cleaned up and dried out. I'm currently looking for a used one. Until then, I'm going to use some 3M weatherstrip adhesive.
I was told to push the seal back into the corner of the B pillar and that it's OK if it causes a gap at the bottom center of the door, since that area isn't prone to leaking.
My only bet is to find a used one in better condition. None to be had for a Gen 2. They are specific, as they have that rough texture portion on the interior side.
thatSHOguy101
