lincster2
Anyone have any experience with the Wavetrac L.S.D. ? I was wondering if it's al that....from all the hype I read it's suppose to be the greatest thing since sliced bread. thanks.
Love mine. Went from a Quafie. Wave-trac is a better drive IMHO.
Can you elaborate as to why you feel this way…??? :thankyou:
Now, The beauty of the wavetrac is that you can make it performance Just like the Quaife or be more like a true Limited slip before you put it in to the car...
-Sam
Is the Wavetrac unit capable of cornering and strait line acceleration at the same time...???
I'll tell you that the Quaife is a Must have. Being able to hammer the throttle through tight corners without wheel spin is crazy. Understeer while under throttle going around a corner is not a Issue for me.
-Sam
I hope not. Sounds painful.
First, I'll ask if you have ever driven a car with a Quaife.
If not...Well.. I'll tell you that the Quaife is a Must have. Being able to hammer the throttle through tight corners without wheel spin is crazy. Understeer while under throttle going around a corner is not a Issue for me. As far as straight line performance, It really does not make a difference because its not a True Limited slip differential. (Its a Torque Biasing differential). I love it.
-Sam
