93EmeraldMTX
would the waterpump be replaced if done by a ford dealership in a 120k serivce?
P'rolly not unless specifically requested or if it was found to be leaking or whining. You can try looking in at the top of the pump housing with a flashlight to get an idea -- if the pump has oxidation all over it, it's probably at least a year or two old (or more), if it looks clean and smooth, it may be less than 12-18 months old.93EmeraldMTX:
alright, thanks.rangerj:
93emerald,
If the work was done by a Ford, or Lincoln/Mercury dealership a record of the service should be in their computer system. Stop at a dealership and ask if they will look it up for you. All they need is the cars Vin.
They keep the records for several years, so if it was done within say 3 years it should be there. rangerj
Agreed. As long as your water pump is working fine and there are no indications of leaks then why change it?dkautumna:
If you are contemplating changing it,why bother with it if you have NO signs of leakage/and or coolant loss?
im changing my CPS, i dunno, i just thought while i was down there...Huntervf:
true enoughHuntervf:
Yeah but why shell out the extra $$$ when you don't have to? There's an old saying that goes "if it's ain't broke, don't fix it!" I'd verify first that the water pump is leaking...if it isn't save the extra $$$ for some fun mods![]()
93EmeraldMTX:
