I had my 2014 SHO in to the shop because apparently the fuel pump driver module went out, which I understand is behind the rear seat (and not in the engine compartment). Today, a few days later, I noticed a lot of water dripping in the rear of the engine compartment. I put it up on ramps and saw that it's coming from what looks like a drain tube that's horizontal and points forward towards the engine compartment. I haven't been able to find out what this tube is supposed to drain. It could be an AC drain, but I haven't used the AC in over a week, and I didn't notice this before today. I only noticed it when I got home from work, and maybe 3 ounces of water have dripped out since then. The vehicle appears to be running fine.
I also noticed today that there was water dripping from the bottom of the rear driver side door, and when I squeezed the rubber at the bottom of the door, 5ish ounces of water came out of the rubber. Apparently that's from the moon roof, and we've had rain here lately so that's a little surprising, but might be unrelated to the water dripping in the engine compartment. I'm not too worried about that, just mentioning it in case it's related.
Any ideas what's going on, or what that tube is?
Thanks.
Thanks.
