Video: ORP Counterclockwise
TimboSHO
Intermediate
Wyoming, MI
Nice driving! Looks like those C6 brake are paying off! What kind of tires and suspension are you running? It looks like it corners nice and flat, and the tires hold real well!
This really makes me want to get back on the road course!
94shodriver
PNW
225/50R16 BFG R1 tires. I'm not going back to street tires! My suspension is koni sport struts with eibach lowering progressive rate springs, G3 subframe, and 22/26 mm sways with rod-ends for the rear links (a noticeable difference in stiffness even over poly bushing endlinks). Roll is well controlled but pitch leaves a little to be desired. I'm in the process of converting to coilovers, this may be my last session on this setup.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
That track looks like a blast! Tarmac looks brand new. And the near constant elevation change and that camber valley of esses was something to experience I bet. Where is this?
94shodriver
PNW
Oregon Raceway Park. They run the track in both directions and can make two separate circuits out of it, lots of variation.
OG-SHOguy
Same as JBeck
Houston, TX
Use of the track was damn near perfect while leading a Porsche and a Lotus....well done sir! well done! :thumb:
Daniel Hill
2017 PP Blue Jeans
Massachusetts
Nice driving! Patient at the beginning, slow in - fast out of the turns, good apexes.
I had similar set-up in my 95. 19/26mm sways, poly bushings, solid aluminum subframe bushings, Tokico/Eibach, front/rear strut tower braces, 96 brakes, braided brake lines.
Once you go R1’s (I had them also) you NEVER go back.
