Vibration with reinforced motor mount?
randy'sho
95 White MTX
High Point, NC
Is it normal to have some slight vibration in my floor board after reinforcing my front motor mount? it isn't bad, but a little noticable when i get on it hard!
ST 2 SHO
WVA
Are ya running a ploy one????? ploy is harder than rubber so yes....you can feel it.
randy'sho
95 White MTX
High Point, NC
thanks guys just wanted to make sure....i did my own reinforcing with a few bolts through the rubber! so far so good!!!
randy'sho
95 White MTX
High Point, NC
yeah it is effectively solid now....i drilled and added two bolts on each side and replaced the center rod with a thicker bolt.....
NJSHO
Clean Your Shorts!
NJ
Yeah I did bolts too and it does add some vibration. By the next oil change you wont even notice it.
