venomizd93
I have som equestions for you SHO experts out there. I have a 95 MTX with 90k on the ticker. First I found out the other day my blend door is messed it keeps banging itself against something....kinda like chineese water torture.
First is it the motor or is it just stuck on something trying to free itself.
The next is the more important of the two. Recently my car has been running from normal to what I consider Hot(not normal)....about the N of the NORMAL on the gauge. The fan seem s to come on at all different times. I don't know if it's the gauge. I've replaced the coolant temp sensor, the themostat w/ a 195 deg. one and the coolant. The radiator is only a year old, hoses are good. No new water pump though. I cleaned the intake(carbon fouled) and that seemed to cure the problem, due to pinging) but now its back to the same old. Just re-sealed the sparkplug seals due to oil all over the plugs....still the same. It seems after it wams up if I stop somewhere and then drive again the idle stays up around 1900 and when I let out the clutch it isn't responsive at all to the gas...Now I know the pump is on it's way ouot because of hard starts every once in a while as well as the gurgling after the car is turned off or a hard start occurs. It seems like I'm gettting some sort of vapor lock. I plan on replacing the fuel pump ASAP, but could this be the cause for the "running hot" condiditon. The water pump is not leaking at all, do they get weak????? I suspect a lean condition might cause the higher idle. HELP headbang
