Vented rear rotors on a '93
Scarochee
Oregon
Hey guys. I just bought reman calipers and rotors for the rear of a '91 and went to put them on my '93, they didn't fit. The caliper bracket is too thick to bolt down with the rotor in place. Is the knuckle different between the solid rotor and vented rotor cars or did they just sell my the wrong calipers?
95GOOSE
Mass/SoCal
Vented rotors
When installing Gen1 vented rotors on Gen2 rear, you also need the "axle shaft adaptors" from the Gen1.
Not to be confused with the "dust shield".
I believe the part numbers are:
F0DZ2C100A for right side
F0DZ2C101A for left side.
Bill
strykr14
Michigan
On a wagon, the two spindles are different. I would think it would be the same for the sedan.
1995mtxsho
Grand Rapids, MI
Already been answered here. Search is good.
The answer you are looking for is: You also have to swap the Bearing/Hub, as the older Hub is 1/8" deeper.
