valve shim 60k question??/
noSHO
ohio is for hustlers
It doesn't work like that. There are different shim sizes, and just because you take out a 2500 (for example) and put a new one in doesn't make it ok. You absolutely must check to make sure each shim is in spec. Sometimes you can take a certain size out, put a new shim of the same size in and end up out of spec on the low side. This is one of those things that is just plain tedious; do it right or don't do it at all.
-Dave
green/black 92, mods
8359139 68b0 00C8006C
fredhurderjr
www.neshospecialists.com
The shims come in all different thicknesses - it's not a 1 to 1 replacement. You need to measure the gap, compare to what the gap is supposed to be, and calculate what shim you need to make up the difference.
It's not terribly hard, just a little time consuming & intimidating. Good luck!
fredhurderjr
Hey Dave - ya beat me!
RStalveyARFF
too many shos
Georgetown, MA
Yeah, you have to remember the shim isn't the only variable in the equation. There can also be cam lobe wear, etc that can account for a bigger gap.
myshonuff
orlando,florida,usa
thanks for the advice.i will order the video 60k first and when im ready the kit.just need to see the valve gap section only taking apart the rest i have done with easily.it would be great if someone could just post a short video just showing the gap measurement by itself.
93nighthawk
Mitchell, SD
Yes it is a tedious job, but would you rather do it or pay ford $1500+ to ***** it? Plus when you do it again in another 60K mi you will know what is going on in the engine. I just used the wisdom off of www.shotimes.com
Eric
'93 Green 'NITHAWK' ATX
120K MI, Fish tank ligts, Sho Shop Y Pipe, Sho Shop SFC's, Removed Silencer, Sho Shop 60K, Replaced Motor Mounts, New EGR/PFE
'78 Green/White Bronco C6 AT
200K mi+ on body, 30Kmi on engine, 351M, 4brl Edelbrock carb, Edelbrock intake, duel exaust, lifted, rusted to **** but can go anywhere...
'95 Mercury Mystique ATX
110K mi, 2.0 I4, studs, Great parts getter for the other two vehicles.
40' x 40' heated garage to work on all 3 :D
Blast7
Rochester, NY
The video is excellent and I highly recommend it.
Car of the Moment
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
PP Y-pipe
Rod Shifter
Blazer Tech Fogs
"ur gonna love that sho, and everytime something breaks down..your gonna swear to all your friends that its going up for sale. and the minute you get it back you fall inlove all over again."~Blue
