22SHO
On my recently acquired 1991 SHO, there are a couple vacuum fittings that appear to be potentially missing a hose, and I don't think the hose would connect the two as they are all of an inch apart. I don't have a picture for you, so you'll have to paint a mental image. On the underside of the intake manifold, adjacent to the Throttle body, and under the air bypass valve, there are two hose fittings pointing straight down. They are in the intake casting, not the throttle body. On my particular vehicle, one of the fittings (the one slightly nearer the firewall) looks like it once had a hose attached, but no longer does. The other fitting has been crimped for some reason and doesn't look like it ever had a hose on it. Does anyone know what these fittings are supposed to be attached to? I've looked for broken hoses or other vacant vacuum fittings, but have found none. Ideas?
