v8 sho performance mod help
bigm1717
Belmont Massachussetts
i have a 1998 sho and i was wondering if people could give me some good ideas on different mods to do to my car and places where i could find these mods, thanks
SuperHO
Mental Patient
St. Joe, MI
First off, get the cams welded....do that before ANYthing....
after that's done, remove the saxocone (silencer tube for the intake in the fenderwell), get some mufflers and let that V8 sing...then take a gander over on www.v8sho.com for more ideas.....
hoboprodigy-
SMOKE
Troy, MI
There aren't alot of easy HP-increasing mods to do on these cars that don't involve either alot of money or alot of time/patience/fabrication skills.
I would suggest:
-UDP
-Exhaust
-Programming, an SCT Tuner from nesho.com or fordspecialists.com
-Some sort of cheap cold air induction system, like the "Porterized" setup.
You could probably spend about ~$1000 on all this stuff, and be into the high 14's.
NebraskaSHO
Harumph!
Omaha
hobo how much did your tranny cost with all the upgrades it has? I know my Tc is on its way out, and I'll need a new tranny sometime. You can PM me if you dont want to post here. Thanks
bigm1717
i have done the exhaust, and was looking for a cold air intake but am having a hard time finding one for the car. anyone have any good places online to get one. and how much does it cost for a cam weld job.
No pre made cold air kits for the car. You have to make your own. I was getting the parts together but aborted it. Cost was at least $250 for a 4" cone filter in the fender with silicone hose in the engine compartment. Let me know if you are interested.
stephen newberg
Ladysmith, BC, Canada
bigm1717 said:
whats the saxacone, you said it was the thing in the inner fender, why would i take that out isnt that like a half assed ram air?
You might want to look around a bit at all the data and articles over on V8SHO.com, as it has a lot on this sort of thing there. I recall an article that had air movement figures and it showed pretty clearly that the sax ended up restrictive, rather than as any form of real forced air.
The simplest system to get cold air in quantity to your motor is some form of 'Porterization'. You will be able to find various descriptions including photos and such at the V8 site. I did mine with just a single chunk of 4" diameter rad hose and did not have to move the air box or any of the other manipulations that some of the other systems seem to require. It was fast and easy. I think I have a photo around somewhere. If you want me to email it to you, let me know.
pax, smn
stephen newberg
I just emailed to you the location where I have a copy of the photo, on Photobucket. Just in case, here it is again:
http://i4.photobucket.com/albums/y136/newberg/MVC-025S.jpg
If you need a bigger version, let me know and I will try to find it in my photo files, somewhere, but I did not see it immediately, so I may not have kept it in another location.
The rad clamp is there only for looks, by the way. The actual connection holing the hose to the air box inlet is done with 3 small stainless steel screws. I had to do a touch of careful trim work to get the hose to fit well, as you have to notch it out for the corner of the airbox, but it was not hard, just requiring care. This went in within a few weeks of getting the car, so it has been there without problems for getting on 6 years now.
pax, smn
bigm1717
motormouth, that looks real good. if i was to just have the cone where the intake box used to be, do you guys recomend me taking the saxacone out?
NebraskaSHO
Harumph!
Omaha
Cone filter where air box was at sucks hot air from the engine compartment. Just get a K&N panel filter and do the porter mod. I FINALLY got around to doin it a month ago.
Sounds pretty good. Not as eerie as without any snorkel coming out of the box though... :oogle:
stephen newberg
You do not want to suck hot air from the engine compartment. The rig that MotorMouth showed is set up so that the cone is in the wheel well gap, which is the same place just running a tube from the air box to the inner well goes, but without trying to put the filter on the end. As noted just above, you get the same, or a better since it is simpler, effect by just putting a good filter in the airbox and running some form or 'porterized' intake pipe to the wheel well. A lot cheaper too, and less likely to come apart in there.
pax, smn
rickshaw
Jacksonville, FL
I second the Porter mod. Very good step by step documentation and the price is right too! Wish I would have done it 100k miles ago!
bigm1717
what i did was i took the filter box out, took the whole saxacone thing out, put a cone filter on and ran some flex pipe through the saxacone path to the front, for kind of a ram air set up, i just need to make a backing plate and kind of heat sheild for the cone.
bigm1717
hey shodude, were can i get one of these tuners? which do you recomend? how much is a cam weld job, because i work at a big garage in watertown and i want to see how much they will charge to do this job. thanks for the help guys!
