V8 Crank Time
Vash
Chris V.
Paynesville, MN
It seems like my SHO takes a little while to start. About 2 seconds worth of crank time I think. Where I would say my Sable (and all of our other Tauruses) are about half that. 2 seconds is not an exact number but it seems like a long time. (Could get a video if you guys want?) Just curious what you guys have for crank time with your V8? Maybe it is nothing, I have no idea this is my first experience with a V8 SHO.
Thanks! Chris
BamSHO
South Williamsport,PA, US
Maybe fuel pump is starting to go. When I start mine up before leaving for work or going home I turn the key on and wait 3 seconds or so then fire it up. Starts right up.
Brian Michael
98 silver Gen3
LJRuddy
Pop lock n drop
Poaceae fields
I have found that if I just get in and turn the key straight to "start" the engine takes a little bit longer to fire up as the fuel pump needs to pressurize the lines. If I let the key chill in "on" for a couple seconds the engine fires up right away.
Vash
Chris V.
Paynesville, MN
i will have to see if mine does the same thing. sounds like this is pretty common with the V8 then. ok makes me feel a bit better haha
Vash
Chris V.
Paynesville, MN
ok i have letting the pump prime and it starts right up every time now! thanks for the info guys!
