Urgent Help needed ASAP!!
TheDailySHO
Minnesota
So I installed the new seal from the top today. Not an easy task because when I would force one side down, the other would pop up. After an hour or so it was finally in so I reinstalled the COP and Took it for a spirited test drive. Removed COP and the spark plug well was bone dry!! Thank God! I'll recheck again after a few hundred miles to make sure it holds but I think it should.
I then installed my Livernois tunes that arrived today and WOW! HUGE difference! Advance track completely off and on exceleration it broke the tires loose just a bit in both shifting to 2nd and again into 3rd. And these are new winter tires with nice soft compound which should never break loose in warm temps like today! Thank you Livermois!
:thankyou::woo-hoo::hail:
brucelinc
Minnesota
Daily, the BPs in the twin cities have 93 and I run it consistently with great results. Strangely, in rural Minnesota, the BPs do not usually have 93. I am not sure where you are located but if you are in the Metro area, there is likely a BP with 93. I highly recommend using it with your tune.
BamSHO
South Williamsport,PA, US
Glad you love you tunes, yeah amazing what a difference they make. Yeah I would def try to find 93 if you can. Welcome to the LMS family.:woo-hoo:
