vortex2450
Buying Parts...
My swapped 3.2l has a lot of valve-train noise, I've checked the timing chain tensioners and they are taught..
It sounds like what a worn out lifter would sound like on a push rod engine.
It's bothering me a lot, I'm running Mobil 1 5w-30 syn with a Mobil 1 filter. The timing belt & tensioner are new...
I've been searching and reading posts and from the descriptions the noises that seem similar are warnings of rod bearing failures..
I do not need that. So should I start planning for doing the rod bearings and valve lash?
FYI: the engine has 143k and it sames pretty well maintained, everything else that came with the engine was clean, the PO seemed pretty capable but I can't make promises..
-Josh
-Josh
