After not being able to work on my tansmission swap for about 3 weeks, I finally spent this week-end on it. I installed the clutch pedal and brake assembly, (a great deal of jiggling, but otherwise straight forward). Reconnected steering rack. Cut hole in floor board and installed shifter. Again very staight forward. Ford even marks the floor board tunnel with dimples where the bolt holes are supposed to go.
Will probably have to change the cat back exhaust, since it interferes with the rod shifting linkage.
Began dressing the 3.2 engine with the 3.0 accessories. Used the 3.2 oil pump. I will close the small opening by the power steering pump with a small aluminum bracket. Swapped the rear panel behind the cam sprockets from the 3.0. which supports the plastic timing belt cover.
Used a hacksaw (and a little WD-40) to cut off the nub on the 3.2 head which interferes with the
3.0 alternator. This took about 15 minutes to accomplish. Installed the 3.0 water pump, the 3.0 motor mounts and the 3.2 a/c compressor. It is exactly as the 3.0, except for the hoses, which match the possition on my 3.2 body. The 3.2 a/c pulley lines up with the 3.0 alternantor and the idler.
Also, I installed the front covers. Everything looks fine.
This is just a dress rehersal, since I still have to take it all of to do the 60K on my 64,000 mi. 3.2.
I will be posting the photos on my crappy web page this week when I have a little time.
